2mb Upgrad
Maddy
2mb Upgrad
yaaaahoooooo I got my 2mb connection Cheesy no problems with the speed, very fast indeed Cool .
Thanx plusnet keep up the good works, i am glade i stuck it out.
Thank you
Nice1
holdtight
2mb Upgrad
Good stuff armran Cheesy just out of interest whereabouts are you and was your exchange upgrade listed for April or June ?
Dont forget to update your details Here so that others that are looking know your exchange has been upgraded
Thx plus net
plus net rocks!
help
help cant get pic under my name
LiamM
2mb Upgrad
You'll need to upload a pic (80x80 / 10k max) to your webspace. Then link to it under the 'Avatar' section of your Profile page (link above).
Phantom_Flan_Fl
2mb Upgrad
bodybag -
Your currently trying to link to an image through Google image search, but all of the URL isn't there.
You should at least have the URL from the site direct, but a lot of sites don't like or let you remote link to images on their site.
As mentioned above, you should try and host it yourself.
thx for advice
cheers dave and liam :lol:
Maddy
2mb Upgrad
Hi holdtight i am in Kesgrave Ipswich, and my exchange was: KGF_DSL_101 Upgrades on this DSLAM will commence in April 2005
hope this helps i have also updated this info on the Upgrade Checker System.
Thank you
armran
holdtight
2mb Upgrad
Cheers !
2mb Upgrad
Well, I'm pleased for you Armran.
I hope I don't have any problems when I get it ^_^... But knowing me I will, as I am magnet for all technical problems.
-Williams1662
