2mb Prem, but speedtest results of 300kbps!?
I've been on the 2mbps premier package for two weeks now, and at first speed results were in the region of 1800+, now i can't keep hold of a reliable speed, ranging from 500 -100 kbps! Speaking with neighbours and performing speedtests on their kit, it seems that the problem stems from BT, so the question is what can I do about it ? I don't wish to pay for a service i'm not getting, or rather a service I might get at 4am on a wednesday. Playing games on this connection isn't possible (which is why I went for 2mb premier) it's fine for 10mins then just lags out and I have to quit. Any help would be appreciated. (My Exchange is Keadby)
1) Welcome to the forums
2) Have you done a bt speedtest? (http://usertools.plus.net/tutorials/id/27)
3) What are your Virtual Paths like on the exchange find out here
Apologies if this sounds like gobledegook I will explain more fully upon your reply.
Hi thanks for your reply. Yes I have done tests using BT's speedtester (in the 12am - 7am range) they return results as I descibed above, my exchange simply says port capacity is green. thanks again
Definiately BT's prob. Good Luck!
Lol cheers the exchange is next door, i'll give em hell 2moro thanks again! JT
