2MB Premier D/L Speeds
Ok, im sorry if this gets asked all the time, but i did try searching to no luck due to the amount of posts.
Whta kind of download speeds should I be getting on 2mb premier? Im not very clued up on things like this but it seems other people on different isp's get much better than me. I usually get around 135kbps max... is this good/bad? Ive had the service a while now, and use a Binatone ADSL500 modem.
Any advice much appreciated.
Marc
Download speeds doing what? HTTP, P2P, NNTP, FTP? Which one do you mean?
I get this sort of speed on a 1Mbps Premier connection so, I guess, you should get roughly double (1850 Kbps or so) on a 2Mbps connection.
Have you run the BT Speed Test or checked your exchange status?
There are a number of threads discussing speed issues.
I would recommend reading the existing threads and appending any information there rather than having many threads running discussing similar issues.
This way information is focused and centralised both for the community and the Comms Team.
As such, this thread is locked.
