17:30 downtime
17:30 downtime
Anyone else experience about 5mins of downtime just now at 5.30pm ?
No maintenance scheduled, whats going on?
17:30 downtime
Nope, no problems here. I was making a ticket during them 5 minutes
17:30 downtime
Yes, i couldn't connect for a minute or two.
17:30 downtime
The addition of the segment seems to have been the cause.
Thanks for pre-warning us plusnet ! Evil
JonathanW
17:30 downtime
This certainly shouldn't be the case. As the segement was brought online during the day, its just that the announcement wasn't made until later on.
Was this a loss of synch, or just an authentication failure that you experienced?
Saturn
17:30 downtime
I had a disconnection too. No loss of sync though.
17:30 downtime
Yes when was the segment brought online? 5.30pm?
It was just a disconnection as usual. No loss of sync. This is the 3rd or 4th time it's happened with others reporting the same thing at the sametime, that has not had any resolution or explanation from Plusnet.
Netgear log;
Tue, 2006-01-03 17:29:43 - LCP down.
Tue, 2006-01-03 17:29:52 - Initialize LCP.
Tue, 2006-01-03 17:29:52 - LCP is allowed to come up.
Tue, 2006-01-03 17:30:34 - Administrator login successful - IP:192.168.0.2
Tue, 2006-01-03 17:30:53 - Initialize LCP.
Tue, 2006-01-03 17:30:53 - LCP is allowed to come up.
Tue, 2006-01-03 17:31:09 - LCP down.
Tue, 2006-01-03 17:31:18 - Initialize LCP.
Tue, 2006-01-03 17:31:18 - LCP is allowed to come up.
Tue, 2006-01-03 17:32:18 - Initialize LCP.
Tue, 2006-01-03 17:32:19 - LCP is allowed to come up.
Tue, 2006-01-03 17:32:22 - CHAP authentication success
Maybe the LCP echo timeout fix hasn't been completely resolved?
JonathanW
17:30 downtime
The segment was brought online shortly before 4pm, though as I've said, the announcement wasn't made untill shortly after 6pm, due to a meeting.
If you're having a problem that is occuring frequently, then I would suggest raising a ticket to ensure that there is nothing on our side causing it. As the problems that we had with Netgear routers was resolved.
17:30 downtime
No it's not happening frequently. It's happened 4 times since the LCP timeout issue was resolved.
On each occasion you've had no idea why it has had happened alledgely.
It had nothing to do with Netgears IIRC, it was just more evident on that router make, as other ppl with different routers had the same issue.
