1-Port Router and Vista
custos
I am just about to set up a brand new system for my daughter and we have today ordered 'Option 1'. Are there any known problems using the 'free' 1-Port Router with Vista?
Plusnet Staff
Plusnet Staff
Fixes: 159
If you are using Vista then you will most likely need to set the router up via ethernet rather than USB.
As routers are non-operating specific this should not cause any problems.
 Chris Parr
 Plusnet Staff
custos
OK - thanks for that. It's not something I have done before but I assume full information is supplied with the Router? Still using a USB connected Modem here with WIN98SE so Vista is something of a challenge. Trouble is my daughter believes I am an 'expert'!
[Moderator's note by Jonathan (chillypenguin): Full quote of previous post removed.]
Plusnet Leader
Plusnet Leader
The router will come with full instructions on how to set up an ethernet connection so don't worry about that.
I'm sure you can convince your daughter that you know exactly what you are doing Cheesy
