very odd unread posts - see picture
Oldjim
Resting Legend
Fixes: 63
23 REPLIES 23
Colin
Re: very odd unread posts - see picture
Hmm, looking now ... but annoying i've read that post. You couldn't do me a favour and reply to it could you?
Colin
Reproduced - looks like it might be something to do with the fact that it's a sticky post. Another one for the list tomorrow.
jelv
Fixes: 10
Colin, if you open any sticky, mark unread, then go to Unread posts and All Unread Topics you can reproduce without needing anyone else to post a reply.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
pierre_pierre
just been down to General Chit chat and looked at the offending thread, then came back to unread post and it had disappeared, Temporary solution  Grin
Cliff_Jordan
... and another thing - the pink bands now overflow into the dark gray boarder in Firefox.
(I have an image but don't know how to post it here - if somebody could explain I will)
Cliff
edit - but having posted the above it's all returned to normal now?Huh
pierre_pierre
at the bottom of the reply is Additional Options, Click that and at the bottom again is a place to browse to your location for the picture which you then post, it comes as thou it was on PM site and not yours
Cliff_Jordan
Cliff_Jordan
Thanks for your help pierre_pierre - but as you can see from the above I still need to keep the "L-plates" on!
The second image is the one that best illustrates the point I was making.
Cliff
jelv
Fixes: 10
Was the overflowing at the same time as you saw the html code in the subject of an unread topic as illustrated in the screen dumps Jim and I posted? (I suspect it was scrolled off the screen) If so it is because that is a very long string with no spaces which means it can't word wrap to break the lines - this then means the subject column is too wide and it pushes the other columns out.
Can I suggest you try the http://www.screengrab.org/ extension. That allows you to grab the entire page, not just the visible part - example attached.
Cliff_Jordan
jelv - yes the html code was further down on the page of the image I posted.
Thanks for the screengrab link, which I've now installed, and which shows that all is ok when the html code is not displayed.
Cliff
Cliff_Jordan
The problem has re-appeared. Earlier today this post did not create the problem, but after replies it has!
jelv
Fixes: 10
This problem hasn't been fixed yet - any sticky subject that has new replies will display like that.
To fix the display, read the topic!
Colin
Should be fixed...
jelv
Fixes: 10
Sorry about this Colin, but...
Replies To Your Posts has just given me:
