shortcuts: hit alt+s to submit/post or alt+p to preview don't work using Apple
Infinity
Seasoned Pro
shortcuts: hit alt+s to submit/post or alt+p to preview don't work if you are using Apple OS, in my case OS 10.6.3
Just as easy to hit "Post"
Re: shortcuts: hit alt+s to submit/post or alt+p to preview don't work using Apple
They don't work in Firefox 4.0.1 on Ubuntu, either. Alt+S opens the History menu, and Alt+P does nothing.
pierre_pierre
they dont work on my netbbook either, using an old firefox and Linux
but I do have boxes labled post and preview below the typing ssection
Fixes: 256
don't work on windows server 2003 with FF4 either..
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Fixes: 62
Don't work on Windows 7 FF4 either
Fixes: 10
Let's keep this short: could someone post if they find a OS/browser combination on which they DO work!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Infinity
Seasoned Pro
Quote from: jelv
Why not just remove the shortcuts if they don't work ?
alt+s Saves page, and alt+p Prints page in Mac OS
Fixes: 62
Help the ignorant  Embarrassed - where are the short cuts listed
Fixes: 10
About 2" down the screen from where you just typed your reply!
Fixes: 62
bollocks  Embarrassed Embarrassed Embarrassed
Infinity
Seasoned Pro
Quote from: Oldjim
Fixes: 10
I think he had already found them!
Quote from: Oldjim
[Censored]  Embarrassed Embarrassed Embarrassed
Fixes: 95
The shortcuts *do* work using IE9, Safari 4.0.4 and Chrome 6.0.472.63 on a Windows XP SP3 machine. I'd imagine other variants of these browsers will probably be OK too?
That leaves the question, do we remove the line of text that refers to these shortcuts, modify it, or leave it as it is?
Fixes: 10
In SMF 2.0 final (released a couple of weeks ago) it has changed to:
shortcuts: hit shift+alt+s to submit/post or shift+alt+p to preview
I wonder why!
pierre_pierre
that does work on my netbook wit old firefox and linux
