"New" icons not showing
Re: "New" icons not showing
It says "English British" Kelly (mine says "English as does yours Mr D) Wink
EDIT: There isn't anywhere obvious to change the option either, either on somebody else's profiles, nor on my own)
hulls
Yep - English British
Presumably there's an "English American" somewhere Cheesy (one of my pet hates)
Kelly
Fixes: 9
Yeah.  It's weird!
It's taking that and forming it as part of the image urls.  Localisation features!  Why you are set to British I'm not sure.  I wonder if it's detecting it or something because I've not seen an option to select it!
Kelly Dorset
Ex-Broadband Service Manager
hulls
Odd that everything else works.  It's only that one icon that's affected as far as I can tell.
Kelly
Fixes: 9
Jonny has mucked around with that image though, so I expect it's not been rolled out to all the places it should.
You sure that is all that's missing?
Kelly Dorset
hulls
As far as I can tell, yes Smiley
Colin
Should be fixed...
hulls
Yep.
Smiley
