"Mark posts as read" options
198kHz
Fixes: 42
In My settings > Preferences > General > Mark posts as read I'm trying to opt for Automatically, after auto-mark period expires, but the period setting box is greyed out.
Is this a fault, or is the option permanently not available?
BT technician (Retired)
3 REPLIES 3
SpendLessTime
Fixes: 86
Re: "Mark posts as read" options
I got the box to un-grey itself (purely by accident)
Just select the "Automatically, after auto-mark period expires" button.
Then click "Save Changes"
Now you can change the "Auto-mark period (Days)"
And "Save Changes" again
198kHz
Fixes: 42
Yay! Works fine now - thanks @SpendLessTime  Smiley
The fact that I was foxed and your discovery was by accident suggests that an explanatory note might be in order on that page.
Any PN staffers reading this?
SpendLessTime
Fixes: 86
Yes the accident part was that I did the first click to select the option and than tab to go to the greyed out box. Tried to enter a number but failed. No surprise there.
As I moved my hand to the mouse, I accidentally hit the enter key which saved the change. And then I noted that the box was no longer greyed out.
If I hadn't tried to use the mouse but kept to keyboard navigation I wouldn't have found a solution. Wink
