community.plus.net giving some packetloss today
Gus
1000 words attached
FTTP 500 regrade from Tues 28th November
6 REPLIES 6
Re: community.plus.net giving some packetloss today
I don't see any packet loss.
$ mtr community.plus.net
HOST: my_desktop                  Loss%  Snt  Last  Avg  Best  Wrst StDev
  1. my_gateway                    0.0%  100    3.0  3.6  2.9  8.4  0.9
  2. lo0-central1.pcl-ag08.plus.n  0.0%  100  37.8  30.7  26.2  97.3  8.7
  3. gi7-12-842.pcl-gw02.plus.net  0.0%  100  46.5  63.8  34.6 327.3  61.5
  4. po4.pcl-gw01.plus.net        0.0%  100  43.7  48.8  37.0 210.9  21.0
  5. gi5-8.ptp-cr01.plus.net      0.0%  100  43.5  45.5  41.2  69.7  4.1
  6. vlan2658.ptp-elb02.plus.net  0.0%  100  44.2  45.5  42.9  89.8  4.7
  7. community.plus.net            0.0%  100  45.0  44.6  39.0  51.0  1.6
Gus
They changed the routing, now my traces don't have the affected hops
jelv
Fixes: 10
Be worth keeping an eye on this. I wonder if this might explain those occasions when the forums seem to hang. I believe there is more than one London to Sheffield link and it might be that load balancing will vary which route is used so the problem could come back.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Here is a trace with nearly the same routing as your original screenshot -
 1. my_gateway                    0.0%    10    4.7   4.5   2.9   7.2   1.6
 2. lo0-central1.pcl-ag08.plus.n  0.0%    10   34.1  29.1  26.7  34.1   2.4
 3. gi7-12-842.pcl-gw02.plus.net  0.0%    10   37.8  37.9  35.7  42.1   2.2
 4. po4.pcl-gw01.plus.net         0.0%    10   48.1  54.7  47.1  99.1  15.8
 5. ae3.pcl-cr01.plus.net         0.0%    10   36.7  40.9  34.9  72.6  11.2
 6. ae1.ptw-cr01.plus.net         0.0%    10   36.1  42.0  35.6  94.6  18.5
 7. te9-4.ptn-gw01.plus.net       0.0%    10   48.9  48.5  46.9  50.8   1.2
 8. gi3-0.pih-cr1.plus.net        0.0%    10   47.7  48.2  47.4  49.2   0.6
 9. if25.pih-lb04.plus.net        0.0%    10   48.0  48.1  47.2  49.7   0.9
10. community.plus.net            0.0%    10   47.0  53.4  46.8  99.5  16.2
jelv
Fixes: 10
I've tried three traces, two gave the other route but this one left London from the same point as the original post - again no packet loss:
C:\Users\John>pathping community.plus.net
Tracing route to community.plus.net [212.159.8.110]
over a maximum of 30 hops:
  0  Elvin06 [192.168.0.106]
  1  dg834 [192.168.0.1]
  2  lo0-central3.pcl-ag04.plus.net [195.166.128.243]
  3  gi1-11-432.pcl-gw02.plus.net [84.92.6.242]
  4  ae3.pcl-cr02.plus.net [195.166.129.42]
  5  ae1.ptw-cr02.plus.net [195.166.129.2]
  6  te9-4.ptn-gw02.plus.net [195.166.129.35]
  7  po4.ptn-gw01.plus.net [212.159.1.138]
  8  gi3-0.pih-cr1.plus.net [212.159.1.177]
  9  if25.pih-lb04.plus.net [212.159.0.18]
10  community.plus.net [212.159.8.110]
Computing statistics for 250 seconds...
            Source to Here  This Node/Link
Hop  RTT    Lost/Sent = Pct  Lost/Sent = Pct  Address
                                0/ 100 =  0%  |
  1    2ms    0/ 100 =  0%    0/ 100 =  0%  dg834 [192.168.0.1]
                                0/ 100 =  0%  |
  2  38ms    0/ 100 =  0%    0/ 100 =  0%  lo0-central3.pcl-ag04.plus.net [195.166.128.243]
                                0/ 100 =  0%  |
  3  37ms    0/ 100 =  0%    0/ 100 =  0%  gi1-11-432.pcl-gw02.plus.net [84.92.6.242]
                                0/ 100 =  0%  |
  4  23ms    0/ 100 =  0%    0/ 100 =  0%  ae3.pcl-cr02.plus.net [195.166.129.42]
                                0/ 100 =  0%  |
  5  23ms    0/ 100 =  0%    0/ 100 =  0%  ae1.ptw-cr02.plus.net [195.166.129.2]
                                0/ 100 =  0%  |
  6  26ms    0/ 100 =  0%    0/ 100 =  0%  te9-4.ptn-gw02.plus.net [195.166.129.35]
                                0/ 100 =  0%  |
  7  29ms    0/ 100 =  0%    0/ 100 =  0%  po4.ptn-gw01.plus.net [212.159.1.138]
                                0/ 100 =  0%  |
  8  32ms    0/ 100 =  0%    0/ 100 =  0%  gi3-0.pih-cr1.plus.net [212.159.1.177]
                                0/ 100 =  0%  |
  9  35ms    0/ 100 =  0%    0/ 100 =  0%  if25.pih-lb04.plus.net [212.159.0.18]
                                0/ 100 =  0%  |
10  39ms    0/ 100 =  0%    0/ 100 =  0%  community.plus.net [212.159.8.110]
Trace complete.
I've just done about 30 to 40 gateway hops to try and get onto "lo0-central2.pcl-ag04.plus.net" (as the original trace) but could only get "plc-ag04" on "lo0-central3", "lo0-central4", and "lo0-central5",  and in doing so none of my packet loss tests showed ANY loss.
