Your session timed out while posting. Please try to re-submit your message.
- Feedback
- Community Site Feedback
- Your session timed out while posting. Please try t...
Re: Your session timed out while posting. Please try to re-submit your message.
24-10-2011 12:52 PM
I am now getting this -
which does not require a logout, but just carry on browsing and it goes away (for a while)
(NOTE: ignore the date on my screenshot, I happened to have caught the same error a month ago and am just using the old picture as an example)
24-10-2011 1:45 PM
24-10-2011 2:07 PM
24-10-2011 2:10 PM
I have never log out set so it shouldn't time me out!
24-10-2011 4:49 PM
24-10-2011 6:05 PM
24-10-2011 6:10 PM
If I then return to the <Notify of replies> it tells me "Are you sure you wish to enable notification of new replies for this topic?" each time, so the status is not being set to 'send reply' - otherwise presumably I would be getting "Are you sure you wish to disable notification of new replies for this topic?"
24-10-2011 9:25 PM
If just scrolling through a thread and then hitting <MODIFY> causes the error message to appear, then no matter how you go back and try again the error reappears EVERY TIME !
However if you click on the relevant <Reply #nn> link first, then click <MODIFY>, it works as expected !
Edit: just a quick test of MODIFY as requested below !
Edit: a second try at modifying
25-10-2011 10:30 AM
Any further issues seen at all? Seems to be behaving for us today, just wondering if there are any problems still. @purleigh, I know there were issues with quoting seen yesterday as well as modifying - that still happening?
25-10-2011 10:37 AM
25-10-2011 10:43 AM
I just tried modifying my Reply#22 twice, and it worked normally.
I will try again later.
Edit: but I did get "Your session timed out while posting. Please try to re-submit your message. " when I tried to post this reply ! - so it's not fixed.
25-10-2011 12:11 PM
Forum Moderator and Customer
25-10-2011 12:23 PM
25-10-2011 12:26 PM
25-10-2011 12:36 PM
It seems a very random issue as to when it happens probably making it harder to track down.
Edit.wondering whether this thread should be merged with the original thread?
- Feedback
