You can`t report to moderator.........
shutter
Fixes: 67
So... I can`t report to moderator on my own postings...
because it doesn`t make sense......  Huh
well, it does make sense, if you want to remove your post... or if you want to the mods to move it to another place...  See  ?
"Oh Yeah.... never thought of that... "        when we decided you can`t report your own post....  Roll_eyes Roll_eyes
4 REPLIES 4
Fixes: 1,491
Re: You can`t report to moderator.........
it's a function of the software, not our implementation of it.
you can always PM if required..
Gus
Reporting your own posts is a handy feature on other forums.  Ok we can see when mods are active here and send a pm, but if none are active then the action wanted to be done by a mod is at least queued for the next mod to login if we are able to report our own threads/replies
FTTP 500 regrade from Tues 28th November
picbits
I just report the post above and mention the issue.
Anotherone
Champion
Fixes: 21
This is history. If you want to remove your own post (within 24hrs) just edit/modify it and just post "deleted" or whatever words you want.
