What are the little icons at the left hand side of each line of forum?
alberthall2
3 REPLIES 3
spraxyt
Fixes: 75
Re: What are the little icons at the left hand side of each line of forum?
If you mean the icon to the left of forum subject lists see the key just above the purple footer section of the page.
David
pierre_pierre
if you mean the ones uder your name
hover over them and it will tell you, there are a lot, but under yours, the LH is your profile, the middle send an e-mail, the rh are you on line or off line
if you mean on the index, look down to the bottom and they are explained there
Topic you have posted in
Normal Topic
Hot Topic (More than 15 replies)
Very Hot Topic (More than 25 replies)
Locked Topic
Sticky Topic
Poll
alberthall2
Gentlemen,
many thanks.  I should have spoted that! Embarrassed
