Users online
maranello
Users online
Just a minor bug to add to the list.
The colour coding key for 'Members' appears to be magenta, but the list of users online has members in grey text, which turns maroon (same colour as 'User group members) when the mouse hovers over the name. Just in case it is significant, I have only viewed forums in IE6, don't know if similar occurs for other browsers.
If I have not given the correct colours I apologise - my wife insists I am colourblind! I tried to change the text colour of the words for the colours used, but there isn't a selection for grey, and maroon/magenta look the same in the preview.
My other car isn't a Ferrari
9 REPLIES 9
jelv
Fixes: 10
Re: Users online
How come this simple little error wasn't fixed?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Kelly
Fixes: 9
Re: Users online
No idea.  I'm going to poke Jonny in the eye on Tuesday when he's back in!  Shocked
Kelly Dorset
Ex-Plusnet Jobsbody
Colin
Re: Users online
My fault. Must have missed it as it's actually hardcoded as member doesn't usually appear as an option
Kelly
Fixes: 9
Re: Users online
[me=Kelly]pokes Colin in the eye. [/me]
Kelly Dorset
Ex-Plusnet Jobsbody
Colin
Re: Users online
Cry
It might actually be easy enough to fix, now I think about it.
[me=Colin]goes off to check...[/me]
Yep - I should be able to fix that quite easily.
[me=Colin]adds it to the list[/me]
Colin
Re: Users online
Fixed... although I need to add the colour for it in using the admin panel.
Oldjim
Resting Legend
Fixes: 63
Re: Users online
Can we have Legend a different colour to Bright Spark they both look yellow to me
Colin
Re: Users online
They both are the same  Grin
Re: Users online
Moved to resolved
