Use of this Community Site Bugs forum
- Feedback
- Community Site Feedback
- Use of this Community Site Bugs forum
15-11-2007 4:15 PM
Use of this board seems to be breaking down.
In Kelly's post at the top of this forum he points to the bugs list - this doesn't seem to have been updated in ages (e.g. the edit poll bug isn't listed).
Also we did have for a time a convention that resolved bugs (either NFF or fixed) were moved to the child board resolved bugs.
There are any number of resolved reports in here that should be moved!
7 REPLIES 7
Re: Use of this Community Site Bugs forum
15-11-2007 4:39 PM
tbh, I'm all up for removing the bugs page now.
Kelly Dorset
Ex-Plusnet Jobsbody
Ex-Plusnet Jobsbody
15-11-2007 4:51 PM
Quote from: Kelly tbh, I'm all up for removing the bugs page now.
I presume you are talking about http://community.plus.net/bugs/
Providing everything listed in there has an open topic in here I can't see why it couldn't go.
15-11-2007 5:19 PM
Yeah, I see the point in having the forum for it, but not the page any more. The page was more about us visibly being 'beta'.
Kelly Dorset
Ex-Plusnet Jobsbody
Ex-Plusnet Jobsbody
15-11-2007 5:25 PM
Are you going to edit your first post to remove the link (that might be sufficient)?
While you are at it, could you change the name of the topic to "Report New Bugs Here - Read Before Posting" and add a section to it:
This forum is only for reporting issues with the Community site and these forums. Issues with other aspect of the Plusnet service (including the main portal) should be posted in the Community Support forum (or one of the other Service Discussion forums if more appropriate).
15-11-2007 5:30 PM
Just asking the guys internally to read this before I start breaking stuff
Kelly Dorset
Ex-Plusnet Jobsbody
Ex-Plusnet Jobsbody
16-11-2007 8:44 AM
Presumably all of these issues have one of your internal problem id's associated with them - for tracking reference purposes would it not be an idea to add those numbers to the topics in this forum? (Perhaps modify the title to have the number in brackets at the end)
18-02-2008 8:44 AM
Not a bug, so cleared out of the bug's forum.
Since it contains a suggestion on the handling of bugs, I'm moved it to 'suggestions'
- Feedback
