Still Showing I am signed in yet claims I am not :(
TORPC
It has been mentioned before & it is still happening
Here is a screenshot
9 REPLIES 9
Oldjim
Resting Legend
Fixes: 63
Re: Still Showing I am signed in yet claims I am not :(
that is because it hasn't been fixed and from past experience probably won't be
Just to add - your comment is there
Chris
Legend
Fixes: 169
The approval of comments is turned on at the moment, the messaging isn't very clear though. As Jim points out, your comment is there.
TORPC
Ah!! I see
I was under the impression that as with some (you only see your comment on your end, until checked) the all can see it
In the instance a slight delay then a F5 refresh does the trick Wink
Kelly
Fixes: 9
It is checked, but they all get approved really quickly.  (unless it's spam Smiley )
Kelly Dorset
Ex-Broadband Service Manager
TORPC
Cheers Kelly
To clarify
Whether or not one is signed / logged in, they must all be checked & approved within 24 hours or sooner
Kelly
Fixes: 9
There isn't an SLA on it, but I think they all go into checking (unless you have an administration account)
Kelly Dorset
TORPC
& I would likely have an administration account under what circumstances ?Huh
I guess that doesn't apply to most them
Kelly
Fixes: 9
PN staff only Wink
Kelly Dorset
TORPC
Now then
That is plain crafty, or strategic Tongue
