Something doesn't like '
Fixes: 1,495
Just tried to report a post and
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 's (adiewoo)', 1, 255), SUBSTRING('adie@woo', 1, 255), 1259750788,
' at line 4
File: /local/www/community/forum/Sources/Subs-Post.php
Line: 1538
Note: It appears that your database may require an upgrade. Your forum's files are currently at version SMF 1.1.10, while your database is at version 1.1.2. The above error might possibly go away if you execute the latest version of upgrade.php.
