Slight glitch with Show Unread Posts
- Feedback
- Community Site Feedback
- Slight glitch with Show Unread Posts
06-08-2007 2:33 PM
Re: Slight glitch with Show Unread Posts
06-08-2007 3:02 PM
06-08-2007 3:32 PM
Will see if it occurs again
Occasional error when using links
16-08-2007 11:34 AM
Problem back again - it can't only be me surely
Re: Occasional error when using links
17-08-2007 12:22 AM
Quote from: Oldjim Problem back again - it can't only be me surely
Assuming that, when downloaded and opened, the file displays plain, processed, HTML output - then yes it does look like a problem local to you.
The only other thing I can think of that could result in that kind of thing happening is the server not parsing the PHP. If that was the case, though, it would be happening a lot more often - to a lot more people - and upon opening the file it would display raw PHP code.
17-08-2007 4:28 PM
Is it the same page? or pages at random?
Next time you get it, download it, and send the file over for us to look at?
Ex-Plusnet Jobsbody
17-08-2007 5:06 PM
Will do - I am trying a new solution at the moment - I have changed the web antivirus settings from buffering scan with full set of databases (1 sec buffering time) to streaming scan with limited set of databases and I will see if that fixes it.
17-08-2007 6:22 PM
17-08-2007 6:28 PM
Ex-Plusnet Jobsbody
17-08-2007 6:31 PM
15-02-2008 4:20 PM
15-02-2008 4:42 PM
18-02-2008 8:39 AM
- Feedback
