Size of box when composing post/PM
- Feedback
- Community Site Feedback
- Size of box when composing post/PM
13-07-2007 4:36 PM
Any chance of a bigger box to type into when composing messages?
The box when starting a new topic is just about OK, although I would much prefer one like on the PUG site.
The box when replying to a message is the same height but noticeably narrower.
When composing a PM the box is even smaller again.
1 REPLY 1
Re: Size of box when composing post/PM
14-07-2007 10:13 AM
Quote although I would much prefer one like on the PUG site.
i agree
also the box is small, but i presume thats because "message: and the box are on the same line... and its going to title bar length. - or is titlebar length of box ?
either way should be a quick fix 😄
IMHO the box you reply in should be the same size as the post will be - helps you lay it out better (Like PUG)
