Site Errors (Slow pages, slow posting, connection reset, uploads failing)
TORPC
Re: Site Errors (Slow pages, slow posting, connection reset, uploads failing)
Also is there any news on the prioritising that Kelly mentioned ?Huh
Anotherone
Champion
Fixes: 21
Here we are, Saturday. Things generally ought to be a bit quieter, especially at this time of year, so you'd expect things to run a bit smoother and more quickly. Nope, this forum has been like treacle since I first came on here at ~0930 and it's no better now  Angry
ejs
Aspiring Hero
Fixes: 25
These forums seem fine to me. Perhaps the combination of workarounds I've made on my computer has made some sort of difference. I even attached two images to a post and it neither timed out nor took a ridiculously long time to complete (although it wasn't particularly quick either).
TORPC
Would you be so kind to compile a full list of your workarounds, so that other can test with & it may also help PN to fix the known issues Wink
Strat
Fixes: 565
I get the occasional spinning load icon when browsing the forum, maybe 10 or 12 a day but not the complete failures that some seem to get.
A couple of refreshes usually sorts it for me.
ejs
Aspiring Hero
Fixes: 25
1. Edit your hosts file or whatever so that community.plus.net is 212.159.9.110 if you are on a PCL gateway, or 212.159.8.110 if you're on a PTN / PTW gateway
2. In firefox, about:config, reduce network.http.max-persistent-connections-per-server to 2.
Perhaps I should make a script that randomly applies or undoes those changes and see if I can tell any difference.
TORPC
Cheer ejs
The proposed script sounds a good way to go Wink
VileReynard
Fixes: 20
I have just changed network.http.max-persistent-connections-per-server from 6 (default) to 32 - instead of 2.
Makes absolutely no difference - but it takes about a second to load anyway.
ejs
Aspiring Hero
Fixes: 25
If you change it to 255 (the maximum) I doubt you'll see any difference either. It's an upper limit. If you make it bigger, it might not be restricting anything. But if you make it very small, then it's much more likely to be restricting the number of connections.
TORPC
For chrome see
chrome://chrome-urls/
not had a thorough look so not sure if the setting is in there yet
Anotherone
Champion
Fixes: 21
Well I changed FF network.http.max-persistent-connections-per-server to 2 this morning, and been using it off and on all day and it's made absolutely no difference whichever community IP address I was connected to whilst on a pcl gateway. - perhaps to be expected. As purleigh mentioned, spurious packets would get stopped at the firewall in any event. It's not clear how this change would ensure receipt of the correct packets anyway.
I'm not saying anything !  Lips_are_sealed
Anotherone
Champion
Fixes: 21
For the last hour and a bit this forum has been a real pain.
Quote from: Anotherone
I'm sorry for not agreeing with everything you have said !   Grin
Anotherone
Champion
Fixes: 21
You plonker  Grin Yes you've been a real pain as well  Cheesy
In the last half hour (approx) - I'm losing the plot now (here come the comments) - even when page has loaded, half the time the style has been wrong. Plusnet, FGS get this sorted.
