Site Errors (Slow pages, slow posting, connection reset, uploads failing)
Re: Site Errors (Slow pages, slow posting, connection reset, uploads failing)
I'm somewhat bemused by the regular requests for "are you guys still seeing problems ?" !  Shocked
Surely if Plusnet were actively looking at this problem, then they would have their own industrial grade packet sniffer (or Wireshark) looking at the packets coming out of their network, and KNOW whether the problem is fixed,  rather than keep asking us whether the problem has miraculously vanished and can be forgotten about.
It doesn't exactly inspire confidence that the Operations team know what they are doing !
Crazy
Kelly
Fixes: 9
I like having confirmation of stuff from our live users, that's all.
Kelly Dorset
Ex-Plusnet Jobsbody
ejs
Aspiring Hero
Fixes: 25
Quote from: ejs
none from source port 80 while or after browsing these forums over plain http.
Plenty from 84.93.230.186 source port 80 today.
Apparently they did capture a lot of data but failed to find the problem. What did they do wrong, did they set a capture filter to only capture traffic going to/from the IP addresses 212.159.8.110 and 212.159.9.110? Thereby not capturing the packets sent with the source address still 84.93.230.186?
Kelly
Fixes: 9
I suspect that might be what happened, but we've definitely seen it now.
Kelly Dorset
Ex-Plusnet Jobsbody
artmo
Aspiring Champion
Same problem cropped up again this morning. Clicked on post and waited ages. I thought the site had closed down!
Today I was using a tablet on WiFi whereas last night I was using my desktop PC.
I'm going off to do something else now, because the forum is failing so frequently at the moment, that it is unusable !  Angry
VileReynard
Fixes: 20
Hate to upset people who have real problems,but...
Whilst this site is probably the slowest on the entire internet, I've never seen it show mangled or blank output.
TORPC
I wonder if / when the DCT / post from work & home do they also see these well known issue(s)
Can all the DCT that use the forum, use the likes of wireshark on their connections & put their input into this thread
As @ one time or another there were some tests albeit on hardware / routers, taken home by DCT (I see no reason why this could not happen again)
As seen it is also making it harder & more work for the Moderators,
Is it making any difference to the DCT posts ?Huh
Kelly
Fixes: 9
The posts timing out / uploads failing problem doesn't affect us internally.
Kelly Dorset
Ex-Plusnet Jobsbody
TORPC
Is there any of the widely known issue(s) that affect you internally ?Huh
Fixes: 236
Quote from: TORPC
It is not that simple - in most configurations, wireshark is not going to see the issues as the problem is hidden from the active PC by the NAT / Firewall.
Quote from: Kelly
Would that be because you connect in a manner which avoids the load balancers?
Kelly
Fixes: 9
No.... and yes!  Complicated. Wink
Kelly Dorset
Ex-Plusnet Jobsbody
TORPC
@Kelly
Would you be so kind, to elaborate a bit further Wink
Kelly
Fixes: 9
Next week if I can.
Kelly Dorset
Ex-Plusnet Jobsbody
ejs
Aspiring Hero
Fixes: 25
If we're lining up a long list of questions, I'd like to know:
How long has it been broken for? (Hint: it's at least over one year)
Why did it take so many months / years for the problem to be investigated?
