Site Errors (Slow pages, slow posting, connection reset, uploads failing)
TORPC
Re: Site Errors (Slow pages, slow posting, connection reset, uploads failing)
Just had
Oldjim
Resting Legend
Fixes: 63
just posted with an attachment and as usual it sat there saying connecting even after it was posted and eventually bounced this up
Oldjim
Resting Legend
Fixes: 63
This morning it is even worse - posting or moderating is getting very difficult
Fixes: 236
Ditto OldJim this morning
Ditto TORPC yesterday for me too
DCT,
Do you have an update on the backed out fixes please?
Kevin
Anotherone
Champion
Fixes: 21
Sending PMs has been excruciatingly slow most of the time as well in the last 2 days!
avatastic
Quote from: Oldjim
Strike! Strike! Strike!  Wink
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
WTF
When I try to submit a post, I (literally) get the following message more often than not:
Network Error (tcp_error)
A communication error occurred: ""
The Web Server may be down, too busy, or experiencing other problems preventing it from responding to requests. You may wish to try again at a later time.
For assistance, contact your network support team.
.. every day.  Kinda irritating.  Can often take 10 or more attempts before it works - fortunately, it doesn't lose the text so it's just a case of keep hitting the Post button
Just got it again ..
TORPC
Have there been any work done to the forum overnight, as it seems quite nippy without issue(s)  atm
Although that said
I wouldn't want to speak to soon Wink
Strat
Fixes: 565
You really like living on the edge don't you TORPC Wink
I haven't had any real problems for a few days now.
TORPC
Well what can I say Tongue
Anotherone
Champion
Fixes: 21
Well I've not noticed any real improvement today, I've even had a "connection was reset" on a PM just now.
Come on Plusnet, get it sorted.
Kelly
Fixes: 9
problem:81869 raised.  We aren't seeing the firewall IP mismatch stuff any more, but we're still seeing the performance issues Sad
Kelly Dorset
Ex-Plusnet Jobsbody
ejs
Aspiring Hero
Fixes: 25
I'm still seeing it.
[tt]*** 2014/07/03 19:13:54 ***
IN=ppp0 OUT= MAC= SRC=84.93.235.210 DST=87.115.my.ip LEN=67 TOS=0x00 PREC=0x80 TTL=56 ID=59301 DF PROTO=TCP SPT=44340 DPT=4019 WINDOW=382 RES=0x00 ACK PSH URGP=0 [/tt]
I sometimes think that your inability to see the problem does not reflect the non-existence of the problem!
Edit: And it's still present if you're not accessing the forums over https:
[tt]IN=ppp0 OUT= MAC= SRC=84.93.235.210 DST=87.115.my.ip LEN=40 TOS=0x00 PREC=0x80 TTL=56 ID=37975 DF PROTO=TCP SPT=80 DPT=4897 WINDOW=913 RES=0x00 ACK FIN URGP=0 [/tt]
I think it's been like that since you undid the fix for it. Did you think it had somehow fixed itself, or did you do some work some other time to fix it and not tell anyone?
Gus
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
Just had that using http://community.plus.net/forum/index.php?action=unread
FTTP 500 regrade from Tues 28th November
AndyH
It's very weird - this morning I could not access the forums from any browser. It just read "waiting on xxx" in the status bar.
If I used wget to grab any page, that worked fine without any issues. I tried that 6 or 7 times.
