Posting template error
jelv
Fixes: 10
I don't know how long it's been like it (I suspect ever since the Flickr option was added) but I think the post template is up the creek.
When you open up the additional options the Attach is below Insert Photo from Flickr which makes it look as though you can only attach photos from Flickr.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
13 REPLIES 13
VileReynard
Fixes: 20
Re: Posting template error
It's been that way for at least 3 months.
I found it hellishly difficult to work out how people were adding attachments to their posts...
jelv
Fixes: 10
Has anyone from Plusnet looked at this? The post from axisofevil somewhat justifies my observation.
Colin
I'll flag it to Tam, since he wrote the Flickr bit.
jelv
Fixes: 10
Thanks Colin
Tamlyn
Darn, it. I think file uploads were disabled when i first implemented the Flickr addon and I never noticed it since they were re-enabled.
Thanks jelv, I'm on the case...
Colin
This has been fixed, I believe.
James
Does anyone actually use the Flickr thing?
Kelly
Fixes: 9
Yep.  Me Cheesy
Kelly Dorset
Ex-Plusnet Jobsbody
jelv
Fixes: 10
Oh OK - it's that I couldn't actually remember seeing any posts in these forums where it had been used. How do they appear?
pierre_pierre
i just popped up, i am used to attaching jpg and gif, does that mean we can post other things, like on the new skin video or powerpoint Huh
Assos
Jelv - Like This...
jelv
Fixes: 10
So what advantage does that give us compared to just inserting it as a normal image (taking in to account the main purpose of these forums)?
Like so:
It begins to look to me that it's more it's something someone did because they could than a useful feature that enhances the dialogue between Plusnet and their users.
jelv
Fixes: 10
This is sorted (Flickr removed) - move to resolved please
