OK - who mucked up the forum
- Feedback
- Community Site Feedback
- OK - who mucked up the forum
01-09-2009 9:24 PM
5 REPLIES 5
Re: OK - who mucked up the forum
01-09-2009 9:32 PM
mines OK? XPSP3 firefox 3.5
01-09-2009 9:34 PM
Vista 64 bit if that is relevant
01-09-2009 9:38 PM
It's like that for me too in Safari (on a Mac). Simple solution is to make your window a bit wider.
01-09-2009 9:41 PM
If you are referring to Replies to your Posts being pushed on to a new line, I can reproduce that by resizing the Firefox window below 1024 wide. Don't forget that the ADMIN link you have isn't there for us mere mortals so it will wrap at a higher resolution for you.
Have you changed your screen resolution or anything else recently? (I assume the screen dump was with Firefox maximised).
01-09-2009 9:42 PM
Sorted - someone mucked things up - see pictures below of two different window widths - seems to change at about 1010 pixels wide
@jelv - Replies to posts on a new line
I very rarely use full screen so I must have been using a slightly wider window previously
Interesting the other headings don't do that - looks though the defined minimum column width in the body and the headings don't match
