New skin bugs and tweaks
Kelly
Fixes: 9
I've started a new thread to put any little thing you spot for us to clean up.  Try and be nice and specific.
Kelly Dorset
Ex-Plusnet Jobsbody
105 REPLIES 105
Kelly
Fixes: 9
Re: New skin bugs and tweaks
- Unread posts / replies to your posts page has the first column very cramped.
- report to moderator option and signature not very tidy on posts.  Could be displayed better.
- no easy differentiation between more popular blog posts on front page.
Kelly Dorset
Ex-Plusnet Jobsbody
James
Kelly & Jonny,
As discussed, on the front page it would be nice to see some form of differentiation between the start and the end of each forum and blog post.
Chris
Legend
Fixes: 169
Browsing between the other tabs (home, blogs, polls) shows a login link in the top corner, trying to log  back in then transports you to the forums no matter which tab you were currently looking at. Once you browse back to that tab it shows 'login' again.
MarkC
If you are reading a forum post (like this one) and you click on the Community logo at the top left it just refreshes the forum post, instead of taking you back to the community front page (which I expected it to do).
On the home, blogs or polls tabs it works fine, on the forum tab it just refreshes the screen you are in.
Mark.
itsme
Does PN do any QA before releasing or do they rely on the community to do their testing?
There is no key for the colours used for Users on Line.
James
About a months worth!
Neil_A
When posting a comment on a news item or blog the returns are taken out. Example:
"Test 1
Test 2"
becomes:
"Test1
Test2"
See my latest comment on the TalkTalk lawyers blog.
James
http://community.plus.net/blog/2008/02/04/talktalk-lawyers-target-plusnet/#comments
Also from Neils comment in his blog, the link he's posted at the end runs off the page.
jelv
Fixes: 10
Quote from: itsme
The new forums have been available for testing for ages and discussed at great length in this very forum!
See New Community Site Skin - Testing/Feedback (210 replies)
and New Community Skin (Take 2) (78 replies)
I honestly don't know what more Plusnet could have done to get users comments before it was implemented!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Kelly
Fixes: 9
Smiley
We'll sort the colour legend.
Kelly Dorset
Ex-Plusnet Jobsbody
itsme
Quote from: Jameseh
Still can't see a key for the colours used for the active users, an example where I mean is below.
Forum - Info Center
Forum Stats491486 Posts in 59990 Topics by 7774 Members | Latest Member: ztestfakenotreal | Latest Post: "Re: New Community Site -..." (Today at 16:32)
View the most recent posts on the forum.
[More Stats]
Users Online65 Guests, 34 Users (3 Hidden)
Users active in past 15 minutes:
pierre_pierre, Colin, pjmarsh, Paula, nadger, Peter Vaughan, Jameseh, pawhe955, Mark, jwing, jelv, Mand, Alex, Ghozer, orbrey, markh, Chris, Simon M, Kelly, adiewoo, Midnight Caller, ddunford, MarkC, BlueRhizome, Strat, Barry Zubel, liam1412, Neil_A, chillypenguin, kilburncat, nevglufc
Most Online Today: 115. Most Online Ever: 241 (26/06/2007, 13:27)
Colin
That's an oversight which will be added back at a later date.
itsme
Quote from: jelv
Quote from: itsme
So what I have pointed out was not picked up by 'available for testing for ages and discussed at great length in this very forum!'.
Does PN generate specifications and test scripts for the software they produce or is it a suck it and see approach. If you ask your users to feed bugs and comments then I suggest they go for the latter.
jelv
Fixes: 10
Colin
The login at the top issue looks to be exactly the same problem as I had with the Wordpress SMF integration on the beta forums. Is it pointing at the right databases? Is it only people who have recently changed their passwords that are affected, would changing our passwords get things back in sync again?
