My signature
- Feedback
- Community Site Feedback
- My signature
My signature
19-10-2013 11:21 PM
Would appreciate if you let me know whats wrong
Re: My signature
19-10-2013 11:53 PM
Re: My signature
20-10-2013 12:10 AM
The forum rule http://community.plus.net/forum/index.php/topic,218.0.html#post_avatar, states -
Quote Signatures should use no more space than 5 lines of standard sized text would, this includes any blank lines and images you choose to use. Image based signatures should be limited to 100 x 560 pixels
Currently your signature is about 741x97 pixels, so is nearly 200 pixels too wide (about the same as mine was)
After spending a lot of time rescaling my signature images and moving text around, mine is now within a few pixels of 560x100.
If you can alter your signature overall width and height to be the same or less than mine, then it will be about right. !
I hope that helps !
Personally I think the signatures should be expanded to 750x120 pixels, and would like to see the number of characters available for BBCode scripting raised (from 600) to perhaps 2000 to make the coding of clickable images and hyperlinks (like mine) easier.
Unfortunately a some of the BBCode character allowance is currently wasted by the inefficient image scaling implementation used by this forum, as I documented here - http://community.plus.net/forum/index.php/topic,116560.0.html.
Re: My signature
20-10-2013 10:19 AM
I show below a screen shot showing the effect (I made a temporary change to my sig)
In the case of the OP the way it is formatted means that it doesn't exhibit this effect as the text wraps as the window is narrowed and as such it breaks the letter but not the intent of the Forum Rule.
To change the sig so it doesn't break the letter of the rule is to change the text to the following
Quote I have BT Total Broadband option 2 and Eve and Weekend calls
I use a BT HomeHub 4 Type A and I have 2 MacBooks and a Mac Mini.
I got my BT service on 10th September
My speed result which is being upgraded to infinity opt 1 unlimited
via CAT6E ethernet
Edit - the new sig is even worse as it breaks the depth rule as well
Re: My signature
20-10-2013 11:29 AM
Re: My signature
20-10-2013 11:45 AM
Quote from: Oldjim The reason for the width limit is that when the signature is wider than that specified it causes the appearance of a side scroll band at the bottom of the post due to the minimum defined widths when viewing in a narrow window
via CAT6E ethernet
Well if it so bad why don't you change it!
Re: My signature
20-10-2013 12:00 PM
Re: My signature
20-10-2013 12:18 PM
EDIT: I see the speedtest.net result has moved to the upper right
Re: My signature
20-10-2013 1:31 PM
Re: My signature
20-10-2013 3:25 PM
Re: My signature
20-10-2013 3:43 PM
Re: My signature
20-10-2013 3:49 PM
Is that better?
Re: My signature
20-10-2013 3:58 PM
Re: My signature
20-10-2013 4:00 PM
Re: My signature
20-10-2013 4:16 PM
as 'Oldjim' might enforce this forum rule - http://community.plus.net/forum/index.php/topic,218.0.html#post_emoticons
[quote=Forum Rules]
Too many emoticons
Some people get over-enthusiastic with emoticons. There should be no need for more than two or three emoticons together in a post.
You could brighten your new signature with an 'emoticons' at the start of each line ?
