Log in Problems
FIXED- Subscribe to RSS Feed
- Feedback
- Community Site Feedback
- Log in Problems
- « Previous
- 1
- 2
- Next »
Re: Log in Problems
08-08-2016 10:53 AM
It's a possibility but since this thread started he has logged in to their other account without any issues.
With me changing the password on their behalf, it shouldn't still be asking for a password reset.
Re: Log in Problems
08-08-2016 11:52 AM
Hopefully he'll come back here and comment.
08-08-2016 12:29 PM
Sorry lads I should have closed this thread. The problem was caused by an old log in that I set up using ,at the time, the email address *@ googlemail.com. This seemed to lock in the old log in which I'm now using with no problems, well almost ,I'm now getting duplicate e mails from OLDJACK1 and my current username oldjack but I can live with that. Thanks for all the suggestions.
Re: Log in Problems
08-08-2016 12:54 PM
If you log-in to your OLDJACK1 account and got to https://community.plus.net/t5/user/myprofilepage/tab/user-subscriptions:notification-settings you can set all the Email Notifications to Never to stop that. If this is only happening in threads where you have posted with both usernames, you could just "Unsubscribe" the thread from the particular username that you didn't want to use.
Re: Log in Problems
08-08-2016 1:05 PM
There's also another trick you can do with googlemail/gmail accounts as well which can help solve the password linked mail account link.
googlemail and gmail end up in the same account, so if you are [email protected] you can change the other forum login email to [email protected] and the posts will go to the same mailbox but the forum sees two different email addresses, and so you get rid of the forum linked email accounts confusion.
Also there are additional tricks - you can use [email protected] (notice the dot added) and it will go to the same email account but the forum will see it as a different address from [email protected] or even [email protected] etc. so you will have several variations there.
Re: Log in Problems
08-08-2016 2:25 PM
Thanks everyone I've unsubscribed from the thread sending me e mails.
- « Previous
- 1
- 2
- Next »
