Inserting images into a post seems a bit of a mess
Fixes: 160
Title says it all see - https://community.plus.net/t5/Community-Site-Feedback/Inconsistency-in-Forum-View-post-count-v-Unrea...
The insert image dialogue has two positioning options on the right, which essentially look the same, but seem non-functional.  As can be seen in the linked to post, the positioning / format of the signature gets screwed up.
8 REPLIES 8
Mav
Fixes: 515
Re: Inserting images into a post seems a bit of a mess
@Townman
If you are talking about the blue boxes with grey lines then they reflect the look depending which of the three positions buttons are selected below.
At least, that's how it looks to me.
Forum Moderator and Customer
Fixes: 160
Hi @Mav,
So it does - not obvious - thanks.
Ive changed the linked to pilots so that the image is centred, with the consequence that the signature is no longer squashed up on the right of the image.  I woukd have expected that the signature was in a <div> distinct from the body of the post, such that it could not be wrapped around the side of an image.
Fixes: 160
@jaread83,
Do not know if this is skin or bone, but can anything be done with the containers such that if the images are floated left / right signature blocks remain below the post and do not wrap around the image please?
jaread83
Fixes: 81
You will need to put an empty paragraph below (block level element) the image so that it clears the float. If I add CSS to clear the float then you will not be able to have text wrap around it which defeats the point of floating images left and right.
I will see if I can put any kind of CSS in to remedy this automatically but it could mess it up for anyone wishing to place images left with text on the right.
jaread83
Fixes: 81
I have added a fix to the signature area to clear floats so it isn't affect by images inserted into posts.
I will likely push changes live this afternoon.
Fixes: 160
Jack,
Yet more magic - this is very much in line with my thinking about how it might be fixed.
Thank you.
jaread83
Fixes: 81
This fix is now live.
MauriceC
Resting Legend
Fixes: 17
I spotted it!  I was in the middle of typing a Post - got the Holding page and then forced to login again!
