How to send Private Messages
Mike90
When trying to send a PM to staff I just get error message saying
"Oops
You do not have sufficient privileges for this resource or its parent to perform this action.
Click your browser's Back button to continue."
Any ideas how to fix this?
Thanks in advance, Mike
7 REPLIES 7
agedgopher
All Star
Fixes: 15
Re: How to send Private Messages
@Mike90
You have to have made at least 1 post before you can use the personal messages.
You will now be able to do it.
Click on the name of the staff member and a new page will open with the personal message option on the right hand side of the screen.
Good luck.
pieterv
Doesn't seem to work for me. I have made several posts but no PM option.
Plofty01
It's not worked for me either as of yet.  I'll keep checking for the option though.
Fixes: 383
@pieterv Who are you trying to PM - your post count is way above the security threshold?
@Plofty01 With four posts on the forum, you too should now be able to send PM's
Plofty01
Hi John,
I can now send PM's.
Thanks.
Fixes: 245
@jab1
I believe that you also need to have verified your email address.
Fixes: 383
@Townman Forgot that bit - it's nearly 10 years since I started here. 😉
