Has the site fonts changed today?
Is it my imagination or have the fonts changed on the site since this morning? I'm asking as I am now using OSX Mojave so it maybe this is the reason, as I only installed it a hour or so ago.
6 REPLIES 6
jaread83
Fixes: 81
Re: Has the site fonts changed today?
No changes have been deployed.
Thanks jaread83 I guess it's down to Mojave then, or I'm needing my eyes tested again.
Fixes: 236
Hi Mook,
Exactly what are you seeing?
I have suggested before that there are issues with how the site loads its content.  Typically I see 3 or 4 changes of fonts during the page load process and sometimes it "sticks" with the "wrong" fonts, I guess due to a rendering or resource failure.
I do not understand why the .CCS is not being picked up from cache rather than (apparently) being reloaded on every page rendering.
Hi @Townman, taking your reply as a perfect example, to me the font looks 'thinner' date I say more elegant than it was this morning when I did my other postings and reading. I installed OXS Mojave and when I returned to the site there was a noticeable change in the appearance of the fonts which is what prompted the OP.
As no updates have been applied then I can only guess that this is down to Mojave having an influence as there's no other reason that I can think of. I agree with you as regards the font changes during load as it is something I have seen myself but this is an over all styling issue in that what I see appears to have changed, albeit for the better.
What I see, does it look different?
The above is what I see, does it look different to what you, or indeed, others see?
jaread83
Fixes: 81
Looks like the Arial font to me, nothing really different here. It might be that Mojave renders system default fonts (in this case arial) ever so slightly differently.
Fixes: 236
The characters look slightly squatter / wider.  O's, C's and e's look rounder as though the letters have been widened a little, without otherwise altering their form. They also look a little bolder.
I agree it looks better, but I think otherwise its the same.
