Has someone changed something
Oldjim
Resting Legend
Fixes: 63
There seems to be a big gap at the top
16 REPLIES 16
pierre_pierre
Re: Has someone changed something
its the sun radiating from there nether reions since they turned up in court Crazy Roll_eyes Roll_eyes
pierre_pierre
or did you mean this bit, see below
James
I'm seeing similar Jim - Are you using Chrome?
It seems to be okay in other browsers.
bobpullen
Fixes: 330
The banner's been aligned with the one we've put on the main website to coincide with our new campaign. If it's not displaying for you Jim then try a forced browser refresh (CTRL+F5).
Edit: Ah, I see it does seem to be a tad broken in Chrome Sad
artificer
not me.  i quite like its clean look.  no doubt it will change when i do my next reboot to try my new kernel.
Oldjim
Resting Legend
Fixes: 63
It's the same on Firefox and IE8 even after Ctrl + F5
pierre_pierre
look carefully Jim, and at my previous, it is not blank, it has radiating sun shine, even in you screen copy
Oldjim
Resting Legend
Fixes: 63
Crikey - that is difficult to see
bobpullen
Fixes: 330
Quote from: Oldjim
Fine in both Firefox 4 and IE 8 from where I'm sat. Guessing from your latest reply that you were struggling to see the gray radiation design on the white background? Chrome did seem broken, but it's fixed now. I raised a problem about 20 minutes ago (ref: 63838) so maybe the web development guys have already fixed it?
Oldjim
Resting Legend
Fixes: 63
So what is the point of a radiating sun design which is almost impossible to see
Andrew_B
Methinks your monitor brightness might be a bit high Smiley
Kelly
Fixes: 9
I flagged this to Jonny this morning who looks after the design stuff.  It's a little washed out looking on the community site when I look at it on my laptop screen.  (That's because it's a rubbish screen I think).
He's going to see if he can tone it up a bit.
Kelly Dorset
Ex-Plusnet Jobsbody
Be3G
I like it! Much nicer than the old mass of pink/purple. The radial lines look fine to me, though I am using a carefully calibrated good monitor so I suppose that's not much indication of how it'll appear to most people.
I got the glitch shown in your screenshot too by the way Bob, and I'm on Safari… but after a couple of refreshes the new design showed up fine. Unless of course that was coincidence and it just so happened that something had been fixed whilst I hit ‘refresh’…
Kelly
Fixes: 9
I had the same issue this morning.  Had to ctrl-F5 refresh it.
Kelly Dorset
Ex-Plusnet Jobsbody
