Forum password reset
philipmpercival
I have had to register a new account as the password reset system, was just telling me to correct the highlighted error (nothing was highlighted).  I used a mixture of letters and numbers.
Any chance of recovering my old account?
3 REPLIES 3
jaread83
Fixes: 81
Re: Forum password reset
Hi @philipmpercival,
I may be able to recover your old account. Can you PM me the username you wish to recover and I will take a look.
philipmpercival
lemming
I had the same problem.  Got a password reset email (needed after the recent system update) and the setting of a new password was rejected, as above.  After no useful response from PN support  I eventually found  a mention on the forum that the reset seemed not to work under some versions of Firefox.  That seems to have been it.  I switched to another machine running an earlier version of FF and the reset was possible.
