Forum Database Errors
Strat
Fixes: 565
Browsing the forum I'm getting the error quoted below a little more frequently than usual.
When I say frequently I mean it occurs most days and usually just once or twice.
Prior to this I could go weeks without an instance.
Connection Problems
Sorry, SMF was unable to connect to the database. This may be caused by the server being busy. Please try again later.
6 REPLIES 6
Oldjim
Resting Legend
Fixes: 63
Re: Forum Database Errors
I have seen the same error recently when going straight to the Member Centre via this link http://portal.plus.net/my.html?action=myconnection
ejs
Aspiring Hero
Fixes: 25
Quote from: ejs
Of the two IP addresses for community.plus.net, the occasional database error only seems to happen with 212.159.8.110, and not with 212.159.9.110.
Interesting about the member centre, I would have thought the member centre uses a completely different database, although again portal.plus.net has a pair of IP addresses, 212.159.8.2 routed via PTN and 212.159.9.2 routed via PCL. And they appear to be behind the same dodgy load balancers or whatever that result in packets with a source port of 44300 arriving at your router.
Pettitto
Fixes: 5
Yeah, we're looking at this and a number of other issues with the Community Site.
We'll let you know when we have more information.
Strat
Fixes: 565
Thanks for the update Chris.
PS It's still occurring.
Anotherone
Champion
Fixes: 21
But note, I do occasionally see this (not especially frequently) and I connect to 212.159.9.110 all the time.
Fixes: 251
Saw it several times prior to 7am today - I doubt the server was that busy then ... unless housekeeping was running?
