Fix toaster pop up message is a bit confused
Fixes: 160
Just accepted a post as a fix on my topic.
The pop-message I saw said (something to the effect of) "Townman just accepted your post as a solution".
That message directed to me is (a) incorrect (it was jaread83's post) and (b) do I really need that toaster message?  If it had been sent to @jaread83 (only) then the message would have been quite correct and appropriate.
2 REPLIES 2
Fixes: 160
Re: Fix toaster pop up message is a bit confused
The associated email could be clear too...
plusnet
Hi Townman,
You marked a topic as fixed.
Topic: Memebr sign up dates have vanished
Author: Townman (Superuser)
Date: 28-06-2017 7:22 PM
Message:
Those changes are now live.
See you there soon!
Best wishes,
Please do not reply to this email which has been automatically generated, you will not receive a response. You can reply on the forum if you wish to respond
manage notification settings or unsubscribe.
Facebook Twitter YouTube
The the email refers to the origional post and gives the 'fixing' post in isolation from its author and other details which might be relevant.  Sorry that staging use was not sufficient to document this before now.
jaread83
Fixes: 81
This is a known bug in the platform which is being investigated.
