End of Summer Time - 26th October 2008
Oldjim
Resting Legend
Fixes: 63
Do we need to manually change the time in our profile or has this been fixed in the new layout
11 REPLIES 11
geewizz
Re: End of Summer Time - 26th October 2008
Oh pants! I'm doing a gig tonight. Will we have to play for an extra hour?  Undecided
pierre_pierre
depends how long your trousers are, the clocks dont change until 0200 hrs
HPsauce
Then you put them back to 1am, wait an hour........ Grin
pierre_pierre
at least M$S seems to be able to do it automatically, what with America on one date, Australia another and then us.
Other forums also have a problem
An early reminder to all that the clocks will go back tonight and as well as all getting an extra hour's sleep/rest you also need to adjust your Timezone in the forum profile.
From tomorrow morning we will be moving to Greenwich Mean Time (GMT). So for our UK readers you will all need to change the timezone setting in your profile to GMT either before you go to bed or when you awake to ensure your posts and those of others display the correct time.
The setting can be found in your profile accessed from the link at the top of the forums above:
In your profile, scroll towards the bottom where you will find the the preferences section and change the Timezone from GMT to GMT+1. If you are not in the UK then you should ensure you are using the correct time offset (+ or -) as necessary.
Unfortunately this has to done manually by every user when the clocks change but it is a simple process. When we return to GMT later this year the process should be reversed.
From This
To This
techguy
That extra hour will be nice from a sleep point of view but I'll have to work an extra hour too
Nooooooooooooooooooooooooooooooooo!!!!!!!!!!!!!!!!!!!
mal0z
Did you work an hour less in the Spring whe n the clocks went forward ?  Smiley
rather like leap year - who gets paid for the extra day ?
Santiago
End of Summertime, beginning of S.A.D. Sad
mal0z
Try working in the north of Scandinavia etc. dark most if not all of the day  Sad Sad Sad
Santiago
I would hibernate for the winter I think
Oldjim
Resting Legend
Fixes: 63
Just to see if the forum time updated properly - and it did  Cheesy
MauriceC
Resting Legend
Fixes: 17
I wonder how Webstats fared?  No shouts so far, so it must have been OK?
M
