Distorting forum layout, FireFox
- Feedback
- Community Site Feedback
- Distorting forum layout, FireFox
01-10-2007 5:00 PM
For example the code block in this thread;
http://community.plus.net/forum/index.php/topic,1816.msg17807.html#msg17807
Chilly
Re: Distorting forum layout, FireFox
01-10-2007 5:28 PM
01-10-2007 7:31 PM
In Sources/Subs.php, line 1127
FIND:
'content' => '<div class="codeheader">' . $txt['smf238'] . ':</div><div class="code">' . ($context['browser']['is_gecko'] ? '<pre style="margin-top: 0; display: inline;">$1</pre>' : '$1') . '</div>',
REPLACE WITH:
'content' => '<div class="codeheader">' . $txt['smf238'] . ':</div><div' . ($context['browser']['is_firefox'] ? ' style="overflow: scroll;"' : '') . ' class="code">' . ($context['browser']['is_gecko'] ? '<pre style="margin-top: 0; display: inline;">$1</pre>' : '$1') . '</div>',
In Sources/Subs.php, line 1165
FIND:
'content' => '<div class="codeheader">' . $txt['smf238'] . ': ($2)</div><div class="code">' . ($context['browser']['is_gecko'] ? '<pre style="margin-top: 0; display: inline;">$1</pre>' : '$1') . '</div>',
REPLACE WITH:
'content' => '<div class="codeheader">' . $txt['smf238'] . ': ($2)</div><div' . ($context['browser']['is_firefox'] ? ' style="overflow: scroll;"' : '') . ' class="code">' . ($context['browser']['is_gecko'] ? '<pre style="margin-top: 0; display: inline;">$1</pre>' : '$1') . '</div>',
This will (100% sure) fix the problem. There IS a neater fix possible, but I can't release it without seeing the contents of PlusNets index.template.php.
EDIT: Edit to change my 99.99% to 100%
13-10-2007 1:28 PM
13-10-2007 9:56 PM
13-10-2007 10:13 PM
13-10-2007 10:25 PM
On the reply screen large code blocks are shown at the same length as the purple headers (with the remainder readable at the RHS of the screen in normal text).
I know it's wrong - but I actually prefer unbroken code blocks.
Obviously it depends on the aspect ratio of your screen as to the level of irritation (if any) caused.
13-10-2007 10:31 PM
How do you mean you prefer unbroken code blocks? Adding the overflow keeps the code all correctly tabbed and placed, it just makes sure the display isn't wrecked in Firefox. (IIRC, code gets messed up with the current settings in IE too, because it wraps when it shouldn't really for clarity of code blocks).
13-10-2007 10:41 PM
It's only really long code blocks that cause problems.
13-10-2007 10:44 PM
If you do that while you are viewing this thread, you'll see that this solution doesn't cause inproper wrapping, but rather it keeps the width 100% and adds a scrollbar to allow viewing of the extended code which can't be shown in the immediate view.
EDIT: Added screenshot to show the outcome of the change, in case there is any confusion.
13-10-2007 11:06 PM
Since I appear to be in a minority of one, then a simple (
13-10-2007 11:14 PM
13-10-2007 11:21 PM
@axisofevil
I don't quite understand what you mean you prefer the current broken version? Any reason why?
To expand, basically my previous solution was a change to the SMF code so that the scrollbar would only be applied from within Firefox, as all other browsers display code blocks within a 100% width, not breaking the layout. Thinking about it, making it display scrollbars on every browser is a much nicer solution, as it means code will retain its structure when being viewed.
13-10-2007 11:26 PM
15-02-2008 4:03 PM
