Deleting a Post
Gussie
Deleting a Post
New User here.
Created a post by mistake - how do I delete it - can not see an option only modify
4 REPLIES 4
Fixes: 1,495
Re: Deleting a Post
you can't delete posts, just drop a mod a pm or report a post in the same thread and someone will sort it for you Smiley
Oldjim
Resting Legend
Fixes: 63
Re: Deleting a Post
You can't
If it really needs deleting - and in your case you just edited it to show deleted which is fine - then use the report to moderator button of the preceding post asking that the following post should be deleted
To answer the follow up question - the delete option was removed after a disgruntled poster deleted their posts en block which caused havoc in the threads
Edit - there you are two answers for the price of one  Grin
Fixes: 1,495
Re: Deleting a Post
Now that's service Wink also removed the post in question..
Gussie
Re: Deleting a Post
