Community Site Bug Fix Progress 13/02/08
jwing
Morning all,
Please find a below an update as to our progress on resolving some of the issues on the community site following the roll out of the new skin.
All the changes which we have fixed currently are available for review on the Community (BETA) site. We will be updating this thread over the next day or so as we fix more and more issues.
Can I please request that we keep all issues raised within this thread for the moment to avoid confusion.
Fixed, and on beta site for review
- On multi-page threads, the pages you are not looking at, are bolder than the page that you are on.
- Noted that the images for merging threads don't appear. (Hit MERGE TOPICS to see what I mean)
- Issues with times being strange on latest news posts
- Login screen from reset your password is broken
- 'New' Icon - Appears in different places
- Avatar's are Shrunk currently
- Quick Edit is broken - possibly dependant on signature?
- Possible addition of line between signature and bottom
- Tables are aligned differently in posts and signatures
- Placement of the last post icon inconsistent between forum index and unread posts.
- Icon on front page of forums - reduce size?
- the "Reply #35" bit on the forums is a link but isn't formatted as one
- Forum message icons are too big
Fix in progress
- When posting a comment on a news item or blog the returns are taken out
- Look at a link to get back to the portal (in addition to logos)
- Comments links don't link directly to the comments (single.php)
- Sort out sub board icons
- IE7 issue with the scrolly sliders
- Formatting of search results screen is broken (goes over right hand margin)
- Front Page - picture placement is a bit wrong in the announcements section
- resolution at 800x600 and the 'My Messages' section is broken.
Potential improvements (TBC)
- Maybe add next and previous buttons into the forum posts
- Related articles on blog posts
Jonny
40 REPLIES 40
jelv
Fixes: 10
Re: Community Site Bug Fix Progress 13/02/08
"Icon on front page of forums - reduce size?"
You've gone too far the other way.
is not pretty. It was far better with the New over the top of the folder.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
jwing
Quote from: jelv
Thanks for the feedback. Not sure what you mean by "is not pretty" personally think its quite stylish, obvioulsy we have different opinions on what we like so will have to beg to differ, as design/style is very subjective Cheesy
We will however look at making the icons slightly bigger. I will say though that trying to make "New" written on the folders readable in a smaller size than is current on live site proably wont be possible, so we may have to look at having "New" underneath or have some other way of marking it as "New".
Jonny
zubel
jwing
Quote from: Barry
http://community.beta.plus.net/forum/index.php?action=unread;all;start=0
Shows some topic titles with HTML markup?
B.
I dont seem to be able to reproduce this? Can you provide a screenshot of what it looks like.
thanks
Jonny
Try this link Jonny http://community.beta.plus.net/forum/index.php/board,3.0.html
6th post down (at time of writing) is what Mr Z means I think.
zubel
Image as requested:
jwing
Quote from: James_H
Thanks James (and Barry)!
Yep looks like we need to potentially add something which strips out HTML code in topic titles. I dont think its a good idea persoanlly to have the HTML parse as it could cause a few issues (to say the least)
Jonny
Wierd - not what I saw entierly!
Anyway, next bug to report.
The "Go" button next to the "Jump to" dropdown doesn't stay to the right on Polls.
http://community.beta.plus.net/forum/index.php/topic,57980.0/topicseen.html
Scroll to the bottom, and you'll see that the button is centred underneath the dropdown for some reason.
Only appears to happen on polls.
jwing
Quote from: James_H
Don't seem to be able to replicate this either, have you dumped your cache before testing it? If it still appears after that could you provide me a with a screenshot as well as what browser and screen resolution you are using.
thanks
Jonny
jwing
We have updated the icons on the beta site following the feedback we recieved thay are now bigger, but not as a big as before Wink
Jonny
ddunford
One more here as discussed..
http://community.plus.net/pollsarchive/
Look down at the 'Did you get some new kit for Christmas?' Poll, you'll see 'Voip' has a mouse over tool tip which is mangling the rest of the content inside that div.
jelv
Fixes: 10
Quote from: jwing
Looks good (anyone looking at this will probably need to do a ctrl+f5 to see the new icons)
jelv
Fixes: 10
Does the little icon change on the sub-forums? (Perhaps someone could make a post in http://community.beta.plus.net/forum/index.php/board,16.0.html (Resolved bugs) so we can see)
Assos
The members online key doesn't match the colours actually in use - for members it shows purple, but they are grey...
