Certificate error
Andrue
Certificate error
Kaspersky is claiming that there's a name mismatch. It has been since the forum opened but I assumed it would be solved fairly quickly. Unfortunately I can't work out how to copy/paste the error message. The only thing I can see from examining the cert is that it's using TLS 1.2 which is obsolete.
1 REPLY 1
bobpullen
Fixes: 330
Re: Certificate error
Should be sorted next week.
