Can't even get in to change any of my settings today!
Looks even more broken than before. Evil
If I try to get in to my profile the drop-down menu just disappears after a fraction of a second, I can't get in to change anything, e.g. notifications. I have tried different browsers with the same result.
And the "open in new window" trick (which used to help) doesn't work either.
I guess there's a URL that someone can post for me - please, pretty please......
Re: Can't even get in to change any of my settings today!
Is this what you need?     https://community.plus.net/t5/user/myprofilepage/tab/user-subscriptions:notification-settings
Call me 'w23'
Thanks for that, just uploaded an Avatar, but it's come out massive! It was only a few pixels square. Cry
I've also discovered that if I use the "open in new window" trick and IMMEDIATELY try to get into settings it works. Do ANYTHING in that window beforehand and it fails. Very weird bugs! Crazy2
Yes, very weird.  Sometimes works, sometimes doesn't.  I think I might just save some of the URLs I use off the 'fly-out' menu as bookmarks and give up on using the menu (at least on the Raspberry Pi which seems to be the worst for this problem for me).
Call me 'w23'
quelquod
Been driving me nuts too.
Often have to click on my avatar or any subsequent menu to get it to stay long enough to do something. This forum is hard work!
Democracy - 3 wolves and a lamb voting about what to have for lunch!
