Can't add comment to community home page
- Feedback
- Community Site Feedback
- Can't add comment to community home page
01-08-2007 11:34 AM
I set the stay logged in option when I logged in
I can access my profile fine so I know I am logged in.
I see Logout at the top.
If I click on the Community logo and go to the front page:
I see Login at the top instead of logout
When I click on an add comment it says I must be logged in to add one
huh?
Re: Can't add comment to community home page
01-08-2007 11:37 AM
I used to get this. Do you get it in a different browser? I believe that it is cookie related.
01-08-2007 11:41 AM
Never logged in to community forum on IE7 before so this will have created a new cookie.
Tried logging in again from the community home page, go to the forum again but clicking the community logo I get the same issue.
01-08-2007 11:51 AM
01-08-2007 11:53 AM
Other than that, I'm not seeing the problem here
01-08-2007 1:30 PM
I am using the portal auto-login if that makes any difference. So I'm auto logged in on the portal and auto-logged in on the forums. Although logging off/on the forums again makes no difference.
Does the community forum use its own cookie or does it add to an existing one? When I get a chance I'll delete all the PN cookies and try again to see if that makes a difference.
01-08-2007 3:53 PM
01-08-2007 3:56 PM
If not, try deleting any cookies for community.plus.net you've got and seeing if that helps.
Ex-Plusnet Jobsbody
01-08-2007 4:13 PM
So hopefully he's on to it!
01-08-2007 4:13 PM
01-08-2007 10:57 PM
I shall need to raise a problem tomorrow to stop this happening.
Colin
01-08-2007 11:24 PM
Well, you can always count on me to break things
02-08-2007 1:39 AM
02-08-2007 9:06 AM
04-10-2007 4:03 PM
Nice one Colin
Also when adding a comment, if you see your name shown without the space, just click on your name to get to the wordpress profile page and you can select the format to display the name. To get back to the community site click on view site
- Feedback
