Broadband usage Calculator
ITWorks
Fixes: 9
Hi all
Not sure if this has all ready been raised but the  Broadband usage Calculator on the homepage (www.plus.net) does not work. When clicked the homepage reloads.
Maybe this has been removed due to the product refresh, if so they link needs removing Smiley
Regards
Mike
7 REPLIES 7
pierre_pierre
Re: Broadband usage Calculator
which home page are you talking about, I have looked at a couple and find any such link
minkey
It's in the sitemap at the bottom of the screen under 'site links'. The URL should point to mybroadbandusage.co.uk but as the OP says, it just goes to the pn homepage.
ITWorks
Fixes: 9
Quote from: pierre_pierre
bottom left of www.plus.net
Regards
Mike
Be3G
To whoever moved this thread in here, can I point out that it isn't a bug with the community site (rather, it's a problem with the broadband usage website), and therefore shouldn't be in this forum?
Fixes: 1,495
I moved it, either the link should be removed from the Related Sites or www.mybroadbandusage.co.uk should be brought back on line instead of a redirect to plus.net.
Chris
Legend
Fixes: 169
Hmm very odd, I've just tried to go directly to www.mybroadbandusage.co.uk and it's redirecting to www.plus.net, however www.mybroadbandspeed.com is still working correctly. I'll get a problem raised on this to get it resolved.
jelv
Fixes: 10
The Measure your Broadband Usage link at the bottom of http://www.mybroadbandspeed.co.uk/ exhibits the same problem.
Entering www.mybroadbandusage.co.uk directly in to the browser shows the same problem.
The link at the bottom of Community pages correctly points to www.mybroadbandusage.co.uk so it's NOT a bug with the Community site and this topic is in the wrong forum.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
