Behaviour of "mark as read"
Oldjim
Resting Legend
Fixes: 63
Re: Behaviour of "mark as read"
I don't have that column at all
Tsonga
Neither do I!  Angry
I suspect that Jelv has the option turned on in his profile, and nobody else posting here does.
Go to your profile, and then to the 'look/layout' settings page http://community.plus.net/forum/index.php?action=profile;sa=theme
Then select Show quick-moderation on message index as checkboxes
Then you will see the column of check-boxes, and you'll be able to mark the ones you choose as read. Wink
Tsonga
Works!  Cheesy
And what is this: "Use quick reply on topic display"?
Oldjim
Resting Legend
Fixes: 63
Fixed - but what does "show quick moderation" mean when you aren't a moderator
It means show the boxes that allow you to moderate the posts.
Its just that the only moderator actions available to you aren't really moderator actions after all. Wink
Quick reply adds a box at the foot of each topic, so you don't have to open a seperate window to reply to a thread.
pierre_pierre
Thats obscure to say the least, how on earth is Joe Punter supposed to know that.  even Jelv didnt know what he had done Shocked Roll_eyes Tongue Undecided
jelv
Fixes: 10
Quote from: James_H
That I do. I don't remember setting that option on - it must have been ages ago!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
shutter
Fixes: 67
Quote from: James_H
Why don`t you have a " Mark as Read "  box anyway...?  (OR, even change the present label in the look/layout to read what it is supposed to mean.....
As mentioned later on.... Who knows what that moderator gobbledegook means?  If no one know, no one will tick it....
I didn't know till I saw this post and went to have a look!
It does give mods a lot of other shortcut options, so I can only imagine that its an SMF naming convention thats a little kooky.
Heres the options that mods get:
Remove selected | Lock selected | Sticky selected | Move selected to: | Merge selected | Mark selected read
Its exactly the same on PUG too, and we use the same forum software there.
If Colin didn't know the option was there, then you are right, the rest of us have little hope.... Wink
