Automatic re-sizing of avatars
- Feedback
- Community Site Feedback
- Re: Automatic re-sizing of avatars
04-04-2007 3:48 PM
Another minor niggle;
Its still possible to use a huge image for an avatar, which is downloaded in full and rendered as a smaller image by your browser.
The example I've added to mine is resized and thus appears to be a normal sized avatar, but is in fact a 3.7MB file. Get a load of them on a page, and folks could soon be wondering where all their http useage has come from.
A real pain if folks are having to use a slow connection to read the boards. (Could cost around £4 to view the avatar example I used if you were accessing via Post-Paid Orange GPRS - supposing you could have been bothered to wait for the download!)
One advantage of not using the re-sizing option is that large avatars can be identified much more easily and removed. This way its pretty hard.
4 REPLIES 4
04-04-2007 4:30 PM
That's definitely a problem.
Kelly Dorset
Ex-Broadband Service Manager
04-04-2007 4:57 PM
You PlusNet avatar looks a little stretched.
Chilly
Chilly
04-04-2007 5:45 PM
Quote from: James_H PS - I'm gonna remove the silly size one now that the point has been illustrated.
That's annoying, I can't tell if I've tweaked the configuration correctly or not 😛
29-05-2007 2:46 PM
Think this works correctly, now.
