Attn :- Superuser group - Annoying Pop-up amounting to harassment.
- Feedback
- Community Site Feedback
- Attn :- Superuser group - Annoying Pop-up amount...
Re: Attn :- Superuser group - Annoying Pop-up amounting to harassment.
19-10-2017 10:28 AM
@Mav wrote:
@ejs wrote:
The only winning move is to not use the forums.
Then what will us mods do
Mav you can have your P45 - oh except you don't need one really do you? ![]()
To the people it has affected it may be better to contact someone like Jarad, possibly through PM's. As annoying as it is for those affected (I would be annoyed if it were me), if you can get as much information to someone at PlusNet, with as much detail as possible, such as what system you are using, software, etc. to try and find the cause of it.
The worst ones I've had are:
- When something works through a development environment fine, works when compiled on a dev machine. Crashes on a non-dev machine. That took me most of a day re-compiling one DLL which I couldn't debug and putting message boxes in to find the line of code that was causing it.
- Also when the same code works on one machine, but not another even though you think they are the same spec. This is what we have here I think
19-10-2017 11:01 AM
19-10-2017 11:06 AM
Yep fair enough @Browni.
It just seems daft this is stored at a cookie level, not in the underlying database against the user, especially when users wish to delete cookies and access the internet through multiple devices at home.
19-10-2017 11:10 AM
If it was stored at user level that would then constitute personal data which is another can of worms to be opened ![]()
19-10-2017 11:15 AM
I know about that. A additional bit flag against the user table is not personal data.
19-10-2017 11:24 AM
As I said before, there isn't all that much I can do about this (I do not have access to the code for surveys and I do not have the authority to disable them either) so there is no point in slinging rude insults my way and telling me to 'do your job' which only makes me not want to participate in heated conversations like this.
19-10-2017 11:32 AM
Thank you @jaread83 for replying.
I can understand your position, and your frustration as there are only limited things you can do.
Also, I can understand people who are suffering with this problem.
We can only work together, and all try not to get too annoyed (as much as it is for us) and give as much information as possible.
19-10-2017 12:13 PM
20-10-2017 12:01 PM
@Browni wrote:
@Alex, @shutter has already shown that he has changed his browser settings so it deletes cookies thus causing his problem, no doubt others suffering the same issue will have done something similar.
Fair enough @Browni, I must have missed that.
If people are deleting cookies, whether it be manually or getting software to do it for you, they'll have to accept that behaviour of these forums (and anything else Lithium based).
20-10-2017 12:07 PM - edited 20-10-2017 12:08 PM
Well talk about irony. ![]()
I just got the survey pop-up after that last post, talking about it. Maybe I'm getting targeted now through my posts.
Sorry made me laugh, though it is not a laughing matter for others I can understand.
I use a Mac, and I assume the code dumps a cookie with a timestamp in it. Then checks the cookie and timestamp and says "It has been more than x amount of time since asking, I'll ask again".
20-10-2017 12:11 PM
This is the cookie when you click the 'no thanks' button. Not sure what it does if you just hit the X button though..
I did this about a week ago and its set to expire 90 days later. Haven't had any since I clicked the 'no thanks' button.
20-10-2017 12:13 PM - edited 20-10-2017 12:38 PM
Yes - sounds like it is working as it should be. Not sure when I was last asked but 90 days sounds about right.
EDIT: Just noticed I had a few sessions of the forums open. Safari will automatically open the browser with all the tabs you had open (handy) unless you tell it not to, and so I got asked on all sessions, so sounds like my cookie had expired. Just in case that helps.
20-10-2017 12:24 PM
I mentioned the 90 days expiry back in post #34 ![]()
20-10-2017 12:43 PM
I also got the survey 'pop up' two days ago, filled in some suitably anodyne responses - not appeared since. So it appears to sort of work! What useful output will be gained from the 5 questions is debateable.
20-10-2017 8:02 PM
@MauriceC and so, from your post..I assume you have had enough of being harassed and given in to the bullying approach... in order to get some peace by completing the survey with a load of rubbish answers...
- Feedback
