Attachments in PMs
Anotherone
Champion
Fixes: 21
Re: Attachments in PMs
Zip.& Txt. But we managed alright with the small selection on SMF. I'm not sure we should allow Word or Excel unzipped? There should be a size limit.
HarryB
Fixes: 256
There's already a size limit in place for attachments Wink
 Harry Beesley
jaread83
Fixes: 81
The problem with zip files is that you can completely bypass the file extension filter by putting whatever you want into the zip file...
I could zip up a folder of files that contained .exe or .bat files that would do nasty things to your computer if you were to run them accidentally..
bobpullen
Fixes: 327
Must admit, office documents make me nervous.
Personally, I'd question anything that wasn't permitted on the SMF install:
jaread83
Fixes: 81
@bobpullen - So its basically the same on here as what it was on SMF?
Oldjim
Resting Legend
Fixes: 63
I would exclude office documents as it is relatively easy to add a nasty to them
In addition to images and pdf I would include the various wireshark formats
HarryB
Fixes: 256
@bobpullen I'm pretty sure that's what me and Chris checked when setting the formats on staging, just including .gif as well
 Harry Beesley
w23
Fixes: 4
I'd agree with excluding .exe and .bat but .zip files do require 'user input' to extract files so are not generally a direct risk of accidentally doing something nasty.
Call me 'w23'
jaread83
Fixes: 81
Okay so file extensions aren't an issue.
The real issue really is that you guys would like to have some kind of file attachment funcitonality included in private messages. I might be able to do this myself by reusing the file attachment component on posts but I have a feeling it will be more involved than that and would need to raise a support ticket with Lihtium to get something like that implemented.
It's on my list!
LouisaMartin
Have just had confirmation back from Lithium on this one.
Whilst it isn't possible at this moment in time, the Products team have confirmed they're working on implementing this in the future. I'll keep an eye on release notes and update once they've confirmed dates.
Ta
Louisa
