Attaching images/files to posts
- Feedback
- Community Site Feedback
- Attaching images/files to posts
16-07-2007 2:16 PM
Privacy issues were mentioned elsewhere in connection with using Flickr images in posts and even referencing an image in ones own web-space can reveal more than the poster perhaps intends.
Adding the facility to attach images/files to posts as provided on the PUG forums would avoid such privacy issues and make the forums self-contained so that deletion of the source image/file would not break the post. The enlargeable thumbnail view used on the PUG forums also facilitates reviewing a topic without the image intruding.
Please can this facility be added?
David
David
David
1 REPLY 1
Re: Attaching images/files to posts
16-07-2007 6:05 PM
I believe it's being looked at at the moment. It was switched on but there was a reason it was turned off a week or so ago. I'll check up on it.
Dave Tomlinson
Plusnet Technology
Plusnet Technology
