Another 'feature' removal
Fixes: 383
Just noticed that the 'Top fix authors' panel has 'disappeared' from the display - is this another 'improvement' or another action designed to nobble the forum?
18 REPLIES 18
James_B
Fixes: 17
Re: Another 'feature' removal
Hi @jab1,
Looks like a bug - no fix leader board data is pulling through when I check.
I'll raise a ticket now.
Thanks for flagging. Smiley
James
Fixes: 383
Cheers, @James_B
Fixes: 383
@James_B Any response from the 'industry-leading' hosts ?
James_B
Fixes: 17
Hi @jab1,
The data issue was resolved late last night so I'm hoping it should start pulling through.
I'll keep an eye on it and raise a new ticket if needed.
James
Fixes: 383
Well, @James_B , it is still a big white space on my machine, but I'll try logging out of the forum and back in later - I usually leave myself logged in, so maybe that is why I see no change, but as I clear everything each night before shutdown...
James_B
Fixes: 17
No, it's still missing for me on a fresh login too @jab1
I just want to give it 24 hours or so to allow the fix rollout to reach our instance.
James
Fixes: 383
OK, I'll recheck and advise tomorrow morning.
James_B
Fixes: 17
Thanks Smiley
James
Fixes: 383
@James_B Still not sorted - you need to be a little more forceful.😁
Fixes: 246
When the objective is to nail a jelly to the wall, being forceful can be counter productive.  Experience suggests that the best in industry are more wobbly than a Sunday trifle.
Fixes: 383
Didn't think of that, @Townman .😁
James_B
Fixes: 17
New ticket raised @jab1. I'm hoping it will be fixed in the next maintenance window.
James
Fixes: 383
When is this 'next maintenance window' likely to be, @James_B ? Also, out of interest, do our 'industry-leading' hosts not have change logs to enable swift resolutions of instances such as this?
James_B
Fixes: 17
Hi @jab1,
It'll either be today or next Monday depending on timings.
It's not related to a change - the leader board is still present in our staging environment. Backend cache has been cleared and and plugins reloaded without success. Next step is a full platform restart in the maintenance window.
In the meantime you can view the leader board here -  Top Fix Authors Leaderboard - Plusnet Community.
James
