TBB Ping Graphs
Madmac
Re: TBB Ping Graphs
ADSL2+ Unlimited with Pro Add-on
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/2fbc9552266cd206253d4a5ccbd86250.html"><img alt="My Broadband Ping - Home broadband" src="http://www.thinkbroadband.com/ping/share-large/2fbc9552266cd206253d4a5ccbd86250.png" /></a>
Fixes: 156
Re: TBB Ping Graphs
Business FTTC
My Broadband Ping
Oldjim
Resting Legend
Fixes: 63
Re: TBB Ping Graphs
Forgot to post - I am now on 80/20 fibre
Starmans
Re: TBB Ping Graphs
PN VDSL2 Unlimited Fibre Extra 80/20Mb (Static IP) (EASTF Exchange)
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/86ab8abc1c4a3f13a0d8003a28ae4f09.html"><img alt="My Broadband Ping - PN VDSL Extra 80/20Mbit" src="http://www.thinkbroadband.com/ping/share-large/86ab8abc1c4a3f13a0d8003a28ae4f09.png" /></a>
beeceegee
Fixes: 4
Re: TBB Ping Graphs
Any ideas why my graph suddenly went red at 10pm last night
I first thought something at this end, but there's another graph showing exactly the same. IP address has not changed
[UPDATE] the gateway pcl-bng03 seems to be the problem; a hop to ptw-bng01 and all is well
jelv
Fixes: 10
Re: TBB Ping Graphs
Chris Pettitt's went solid red at exactly the same time as yours!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 156
Re: TBB Ping Graphs
It is nearly 9 months since I posted a link to my revised BQM (forced change of fixed IP address) here - http://community.plus.net/forum/index.php/topic,106312.msg1208375.html#msg1208375 - is there a plan to review this monitoring and apply the proffered updates please?
This was put in place to illuminate patters of behaviour (failures) across the user base.  Is there still merit in this?  Are there other tools in place now which provide that holistic view of the world?
jelv
Fixes: 10
Re: TBB Ping Graphs
If you are on FTTC, yes: http://www.mydslwebstats.co.uk/
tijara33
Fixes: 6
Re: TBB Ping Graphs
I'd forgotten all about this although I am still sharing my live graph.
As a matter of interest, at about 04.30 this morning, as you can see, my latency returned to normal after several weeks of being at the higher value. My speeds have also returned to normal after losing 20% during the same period. PN faults reported that everything was "within limits".
What is likely to have occurred?
Apologies if this is a very stupid question, I'm just a curious OAP!!
Thanks,
Nick
PS There was no change of gateway.
KevinG
Re: TBB Ping Graphs
Quote from: tijara33
Interleaving removed.
tijara33
Fixes: 6
Re: TBB Ping Graphs
Thanks, although I'm not a lot wiser. Why would it have been applied in the first case, about 4 weeks ago?
Fixes: 156
Re: TBB Ping Graphs
At the risk of taking this thread right off topic, can a change to interleaving be applied without a drop of PPP?  A drop of PPP and remaining in the same gateway would be unusual.  Does the router suggest a break in the PPP session (connection time)?
tijara33
Fixes: 6
Re: TBB Ping Graphs
No, the router has been connected for over 3 weeks.  Smiley
KevinG
Re: TBB Ping Graphs
I don't know about ADSL, but on FTTC all sorts of things can happen without the PPP session being dropped. Taking this thread off-topic is probably academic now as the graphs are clearly not being maintained any more.
KevinG
Re: TBB Ping Graphs
Errors, instability, for a period.
