TBB Ping Graphs
Gus
Re: TBB Ping Graphs
Mine can be moved from 21CN Unlimited to Fibre Unlimited as of today 13th May, same IP address so no change in the link that is already in place
FTTP 500 regrade from Tues 28th November
Fixes: 1,483
Re: TBB Ping Graphs
you can join the queue Wink Roll_eyes
Chris
Legend
Fixes: 169
Re: TBB Ping Graphs
Sorry these haven't been updated in a while, I'm not sure when we'll update them but I'll flag this thread up
Re: TBB Ping Graphs
Here are my links to add to the queue (both static) :
20CN - Unlimited Pro
<a title="Mook WAN One" href="http://www.thinkbroadband.com/ping/share/781dfb6a4e68958f4371f3ffe50e32e9.html"><img alt="Mook Ping Graph One" src="http://www.thinkbroadband.com/ping/share-large/781dfb6a4e68958f4371f3ffe50e32e9.png" /></a>
<a title="Mook WAN Two" href="http://www.thinkbroadband.com/ping/share/bf51422a6082d1b73237a2c32d90b746.html"><img alt="Mook Ping Graph Two" src="http://www.thinkbroadband.com/ping/share-large/bf51422a6082d1b73237a2c32d90b746.png" /></a>
jelv
Fixes: 10
Re: TBB Ping Graphs
Mine needs moving to Unlimited Fibre
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
avatastic
Re: TBB Ping Graphs
Good luck with that one jelv, I've been waiting since 04/08/2014, 16:51 to have mine moved to Fibre  Grin
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
hillyfields123
Re: TBB Ping Graphs
Quote from: Chris
Thanks Chris.
deejayburnout
Re: TBB Ping Graphs
I am trying to set this up on my new Fibre setup but all i get is red. I cannot find out how to set it up as asked.
jelv
Fixes: 10
Re: TBB Ping Graphs
Which router do you have?
Oldjim
Resting Legend
Fixes: 63
Re: TBB Ping Graphs
if it is a new one using the Plusnet router - it won't work as responses to pings are blocked unless you do some really extensive fiddling
jelv
Fixes: 10
Re: TBB Ping Graphs
Just found this:
Quote from: deejayburnout
Morning Peeps
I am running the new Sagemcom Plusnet Fibre router ( the one with the pink legs ) and however fast the fibre is, the WIFI signal is poor and slow. Very disappointing. I am looking to replace it with an aftermarket one, but do not know where to start. Can any of you kind people recommend one to me.
It must have
2.4ghz and 5ghz bands and at least 1 USB port for external HD.
Not bothered by looks as it is going under the stairs at home
As Jim posted getting this router to respond to pings (and hence work with the tbb monitor) is not easy.
avatastic
Re: TBB Ping Graphs
Quote from: avatastic
Quote from: Matt
I've updated the page with all of the updates and I've removed any graphs that weren't working. http://community.plus.net/ping-graphs/
Let me know if there are any problems or if I've missed anyone.
Thanks,
Matt
Mine needs moving to Fibre Unlimited now...
Happy birthday request! 1 year old today!
Mine STILL needs moving to Fibre Unlimited now...
[Moderator's note by Adie (dvorak) fixed quote
[color=orange][OPs note: quote was fine.It really has been a year since I made the OP requesting my graph be moved to fibre.
Oliver
Re: TBB Ping Graphs
Unlimited Fibre Extra
<a title="Broadband Ping" href="http://www.thinkbroadband.com/ping/share/d6c511efc3e24dbc02031b08a7571837.html"><img alt="My Broadband Ping - Unlimited Fibre Extra" src="http://www.thinkbroadband.com/ping/share-large/d6c511efc3e24dbc02031b08a7571837.png" /></a>
robbiecollie
Re: TBB Ping Graphs
jelv
Fixes: 10
Re: TBB Ping Graphs
My graphs can be removed (I'm no longer on the IPv6 trial and I'm not on 20CN).
I do wonder if there's any point in people posting in this topic considering how long it is since Plusnet last made any updates!
